PCV valve location
Maddog26
New Member
North Carolina
Anyone know the location of the pcv valve on the Palisade? I sure would appreciate a picture showing location or a description telling of location. Also does anyone know if you put an oil catch can if it would void warranty? Thanks!!!
Jgowen
New Member
Snellville, GA, USA
2021 Hyundai Palisade Calligraphy
#2
I haven't had a chance to confirm if there are any differences, but the PCV on the GDi 3.8 from the Gen Coupe is on the rear of the passenger side valve cover. Adding a properly routed catch can should not void your warranty, just make sure it is a sealed can and not vented, as the PCV needs vacuum to function properly. If there is any question on your dealer flagging your warranty, simply remove it before you take it in for any service.
Litlbuddy
New Member
Long Island
2023 Palisade Calligraphy
#4
I saw the location on YouTube. You could search there
